Set screw connectors
Discussion in 'Home Theater Projects' started by BrianVan, Jan 4, 2004.
  1. BrianVan
    BrianVan Auditioning
    Aug 24, 2003
    8
    When installing set screw connectors to the ends of speaker wire, what is the best way to do it? Do I put the set screw directly on the bare wire or do I push the wire in as far as it goes and screw the set screw on the outer shielding?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    The screw is what makes the mechanical & electrical contact to the wire. You want to clamp down on the metal, not the insulation.
