Serious flaw with some receivers
Discussion in 'Archived Threads 2001-2004' started by RichardMA, Apr 20, 2002.
  1. RichardMA
    RichardMA Second Unit
    Apr 16, 2002
    446
    A report surfaced that indicated the Denon 1602 and
    a couple other receivers will mute out when in Dolby Digital
    mode and trying to play the "Pearl Harbor" DVD and a couple
    other discs. I wish I had better specifics, but Denon is
    working on the problem. It also effects other receivers
    using a "Crystal Semiconductor" chip.
  2. RichardMA
    Apr 16, 2002
    446
    Addendum to the "Crystal semi" problem.
    Disregard the post for the time being. It's possible
    this problem is related to "Cirrus" semiconductors
    used in home theater products.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    This has been covered in other threads I believe, nothing new. (Although it is not a good thing.)
    Also, I think that Cirrus bought Crystal, or the other way around. Same company (now).
  4. RAF
    RAF Lead Actor
    7,061
    Note: The Cirrus chips in the Outlaw 950 do not have this flaw, because it was discovered before the final code was produced for the chips in this unit. I tested all DVDs involved and had absolutely no problems with them.
