Serendipity: Possible Glitch with the Credits' Text using RP91 Panasonic????
Discussion in 'Archived Threads 2001-2004' started by Joseph S, Apr 14, 2002.
  1. Joseph S
    Joseph S Cinematographer
    Dec 23, 1999
    2,862
    I'm wondering if anyone else has had this problem. My DVD Player is a Panasonic RP91.
    On the credits of "Serendipity" the text suddenly starts jumping/stuttering. The music remains continuous and there is zero interruption in it. The text seems to scroll fine in FastForward/Rewind mode. I'm wondering if the credit font is causing a weird glitch with my DVD Player. Seeing as this is a common DVD player in this forum, I'm guessing maybe the other two buyers of Serendipity may have noticed or not noticed this?? [​IMG]
    Thanks.
  2. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    My rented copy of Serendipity glitched and froze on the end credits, on a Sony DVP-S9000ES. If I fast forwarded, it would resume, but then freeze a few seconds later. I wrote it off to a smudge/scratch on the disc, but the disc looked clean upon inspection. The rest of the movie played perfectly.
    KJP
  3. Chad Gregory
    Chad Gregory Supporting Actor
    Oct 11, 2000
    630
  4. MaxY
    MaxY Guest
    I don't think this is a player related problem.
    I watched it in the bedroom the other night on a Sony 650 5 disc changer.
    Though my player did not pause, it did seem like the credits in the transfer were kind of jumpy and un stable while the soundtrack was fine.
    Max
  5. JohnS
    JohnS Producer
    Jan 17, 2001
    4,830
    153
    4,110
    John Steffens
    I just watched Serendipity on a JVC XV-D723 and I experience the same problem.
    The credits jitter up as the music plays fine, but it only happens for about a nimute
  6. Kevin Fox
    Kevin Fox Stunt Coordinator
    Jul 14, 1999
    79
    Same problem on my Toshiba SD-3109 last Monday night. Because the soundtrack had no such problem, I wondered if it was intentional (sort of like the end credits of Moulin Rouge), but I couldn't think of a convincing reason why the filmmakers would do it. It definitely appears to be an actual mastering defect and not player-related.
  7. Joseph S
    Dec 23, 1999
    2,862
    I had a feeling it wasn't just my disc. Normally when the disc is bad the video pixelates and the audio cuts in and out. This time the audio was uninterrupted and there weren't any pixelations. I guess there's no point in returning it at this point, since all copies will have the same issue. Hopefully, Disney will correct it eventually. Thanks for confirming my suspicions.
  8. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,574
    741
    9,110
    Saw this in the theater and any effects at the end I don't think were intentional (at least not that I remember). Still haven't had a chance to watch my copy on my RP91 but will try to spin it up tonight.
    It's only on the end credits? Not on any part of the movie?
  9. Chad Gregory
    Oct 11, 2000
    630
    Carlo,
    The movie is perfect throughout, but immediately after the credits begin the video begins to jump.
    -Chad
  10. Randy B A
    Randy B A Supporting Actor
    Feb 11, 2002
    783
  11. Ken Seeber
    Ken Seeber Supporting Actor
    Nov 5, 1999
    787
    2
    Disney has been using the multi-angle feature for awhile now to present credits in different languages. The only way to see the difference is to select the alternate language from the main menu before you start the movie.
    My guess is that this is what's causing the problem. I saw a slight hiccup at the beginning of the end credits on a rented copy of "Pearl Harbor." Other Disney titles have been smooth for my Sony DVP-S300.
    I think we may want to begin raising this issue with Disney so their people can find a better way to author the DVDs.
  12. Colin Jacobson
    Colin Jacobson Producer
    Apr 19, 2000
    6,304
    779
    9,110
    Just to echo the other statements: I saw it on my Panny 5-DVD changer as well. From my review:
    "I did note one odd problem with my copy of Serendipity. During the end credits, the picture became jerky and the names did not scroll past in a smooth manner. I thought that something might be wrong with my DVD, but the sound showed no blips, and in my experience, when one has a defective disc, the two usually go hand in hand. Frankly, I expect the problem does reside in my particular copy and not the encoding itself, but I wanted to mention this issue in case it came up for others."
  13. Yumbo
    Yumbo Cinematographer
    Sep 13, 1999
    2,227
    glitch also on my Onkyo 555.
  14. DaViD Boulet
    DaViD Boulet Lead Actor
    Feb 24, 1999
    8,800
    3
    Well, if you have anything to say to Disney...There is a toll-free # and an email and they *do* listen to customer feedback.
    BTW, have all of you called and emailed Disney yet telling them that just like thousands of other DVD collectors out there you don't want them to offer P/S only DVDs...like several announced titles including Muppets Treasure Island?
    http://www.hometheaterforum.com/htfo...568#post613106
    So, if you want to have the credits work properly on 16x9 WS DVDs that aren't Panned and Scanned-only...
    CALL THEM.
    -dave
  15. Marty Christion
    Marty Christion Stunt Coordinator
    Oct 3, 2001
    229
    David's right. In addition to posting here, you should call or email Disney, so they can fix it.
  16. Rick Deschaine
    Rick Deschaine Stunt Coordinator
    Feb 29, 2000
    193
    Just wanted to say, I've got the same problem on my Panasonic DV-37. I was hoping this was a bad batch of discs, but it sounds like all the discs are bad.
  17. Carlo Medina
    Oct 31, 1997
    10,574
    741
    9,110
    Just to confirm, same problem on my new-firmware (Oct 2001) RP91.
    Anyone hear back from BV?
  18. Deane Johnson
    Deane Johnson Supporting Actor
    Jan 27, 1999
    524
    Same problem with my SD-4700. I'm at least glad it's not my player.
    Deane
  19. Gary W. Graley
    Gary W. Graley Second Unit
    Feb 9, 2001
    265
    Same with my Sony 560, glad to hear that others find it as well, I was worried that something other was wrong!
    But overall the movie was great, fun easy going type movie, recommend it to anyone.
    G2
  20. Jim Badger
    Jim Badger Agent
    Oct 10, 1999
    43
    I just played this tonight. At 40 seconds into chapter 16 the video got jumpy for pretty much the remainder of the credits and at 2:05 into chap 16 the audio got all distorted for about 5 seconds.
    My player is a Sony S550D.
