Separates newbie has questions.
Discussion in 'AV Receivers' started by John Pine, Sep 7, 2004.
  1. John Pine
    John Pine Supporting Actor
    Feb 27, 2002
    989
    6
    110
    John Pine
    I’m considering running a H/K PA2000 (bridged) from my H/K 525 “Pre Out” for my mains. This will be my first experience with running separates and I had a few questions. Will this effect any of my setups for “Channel Adjust”, “Delay Adjust” and “Crossover” settings for TosLink, Video 1 or “8 Channel Direct” analog inputs used for my Denon 2900? For SACD/DVD-A playback I’m using “6/8 Channel Direct” mode on my 525. I don’t think those analog inputs will be effected but what about the other inputs?
  2. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    The process:
    1) Disconnect speakers from 525.
    2) Connect speakers to 2000, connect preout leads to 2000.
    3) Recalibrate channel levels for all inputs.
    That's it. Delay, crossover, none of that will change. The additional power will probably cause your main L/R levels to be slightly off, but once you calibrate those back in (or calibrate everything else to match), you'll be fine. Only the levels need to be adjusted. Globally.
  3. Andy_Steb
    Andy_Steb Stunt Coordinator
    Apr 9, 2003
    64
    Drew is correct. Leave delay and crossover alone, recalibrate system for all input sources (channel adjust)
  4. John Pine
    Feb 27, 2002
    989
    6
    110
    John Pine
    Thanks guys, that's exactly what I wanted to hear!
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
  6. John Pine
    Feb 27, 2002
    989
    6
    110
    John Pine
    Wayne thanks for the link. I guess you are referring to the higher THD issue when bridging an amp. Here are the specs on the PA 2000 from H/K:
    4 x 45 watts @ 8 ohms, 20Hz - 20kHz,
  7. John Pine
    Feb 27, 2002
    989
    6
    110
    John Pine
    "Should I be suspicious of the fact that the THD is listed the same whether the amp is bridged or not?"
    Anyone?
