Seeking HDTV with these specific features (1 Viewer)
Hugh_Anthony
After "inheriting" some money I talked my girlfriend into using part of the money for a new TV, but it's not my kind of field... I don't really know how to tell a good HDTV from a dud, and was told to seek advice from the knowledgable people in this forum.
The only thing I do know is that the TV has to support 720p (for games) and 1080i (for German HDTV broadcasts), have an NTSC and PAL tuner, cost less than $2500, be gaming compatible (no lag or burn in), be 40 inches or larger and, if at all possible, support both 120 and 240 volts.
Does anyone know of such a television?
If there is anything else I should watch out for, please be so kind and point this out to me. As I've said, I'm lost when it comes to television technology, and I would really appriciate the chance to expand my horizon.
I'm sure this kind of question gets asked a lot here, "which HDTV should I get?", so a special thanks to you for taking your time to read this. :)
TicoTVA
I'd suggest that you consider the DLP you can definitely stay in the range you are looking at
SAMSUNG HLR4667W/HLR5067W/HLR5667W
LCD might be tough because the LCDs cost more to manufacture
compared to DLP. Most 40" plus LCD start around $3500
With Plasma you might exerience burn-in so let me know what you think.
Tico
[email protected]
Hugh_Anthony
Sadly none of those seemed to have hit Europe yet,... or at least Germany. If I read the specs of those three TVs correctly they have everything I want, expect the ability to display PAL... which is a shame... otherwise I could have imported one.
When it comes to Samsung DLPs released here I've only found
-SP-50L6H
-SP-46L6H
and finally the SP-50L7H... and when I laid my eyes upon it, I felt what must have been love at first sight. It has everything I wanted and looks so darn sexy it hurts.
There's just the issue of price... but I guess where there is a will, there is a way.
Thanks for helping me out here :)
Brad_c_g
I have read that the samsungs have a delay with games. I have not witnessed it first hand though. So if you're gaming a lot the Samsung might not be something you want. I would definitely test one before purchasing.
MJL
