Robin Hawk
- Nov 12, 2024
- Robin Hawk
I’m finalizing my home theater design for a 5.1.2 Atmos setup in a room with a sloped ceiling and could use some technical advice on optimal speaker placement. The ceiling pitch is about 20 degrees, which is causing some concerns with the placement of the Monitor Audio CP-CT260 in-ceiling speakers for the Atmos channels.
fmaapk.com
Gear:
- Front L/R: Monitor Audio Super Slim WSS130 in-wall speakers
- Center Channel: Monitor Audio matching center (still debating whether to stick with Monitor Audio or switch to a more compatible option like the ELAC Debut Reference for better synergy)
- Rear Surrounds: Monitor Audio WSS130 in-wall speakers (considering mounting vs. stands)
- In-Ceiling Atmos: Monitor Audio CP-CT260 (concern about angle due to sloped ceiling)
FM WhatsApp APK (Updated) v10.10 | Latest Anti Ban Version Download
FM WhatsApp APK v10.10 and v9.98 2024: These are the most valuable versions of WhatsApp, which mainly focus on your Privacy and Security.
Main Challenges:
- In-Ceiling Placement with Sloped Ceiling:
The CP-CT260 ceiling speakers are designed for flush mounting, but given the ceiling’s slope, I’m unsure whether I should angle them directly towards the listening position or leave them at a fixed angle. If angled, I would need to ensure the speaker dispersion doesn’t affect the overhead soundstage for Atmos. Any advice on how to mitigate unwanted reflections or potential sound diffusion issues with the pitch? - Speaker Synergy:
Considering I’m going with Monitor Audio in-wall speakers for the front L/R and rear surrounds, would it be best to stick with the Monitor Audio center for tonal consistency, or can I mix and match with an ELAC Debut Reference center for better performance in a larger room? I’m aware of potential differences in tonal character and would like to avoid any issues with center channel clarity. - Room Orientation:
I’m contemplating reorienting the seating arrangement by rotating the room 90 degrees to avoid direct sunlight exposure and to improve symmetry. The room dimensions and layout could benefit from better soundstage width and rear surround coverage. Would this shift be a good move acoustically, or would it mess with speaker dispersion, especially for the Atmos channels?
Additional Considerations:
- Speaker Stands for Front L/R: I plan on using high-quality stands for the front L/R to avoid wall reflections, but am open to feedback on how to place them optimally for the best imaging and low-end response.
- Wire Routing: I’ll be running 12-gauge speaker wire for the entire setup, with a focus on minimizing impedance drops over distance. Any recommendations on cable management to ensure signal integrity, especially for the ceiling-mounted speakers?
