Seeking advice on Laptop Purchases
Discussion in 'Computers' started by chung_sotheby, May 15, 2003.
  1. chung_sotheby
    chung_sotheby Supporting Actor
    Apr 8, 2002
    857
    Hi, I am looking to purchase a new laptop. Looking ideally to purchase from Dell (already have purchased 4 computers from them), but have some reservations about their new systems. The models I am looking at are:
    Inspiron 5100
    Inspiron 8500
    Latitude D800
    Most of the work I do is with CAD and Graphics (Photoshop, Illustrator, et.), so I need a system that will be used mostly as a desktop replacement. Looking to keep the budget below $2k. Need the laptop to be reliable and steady, liable to be left on for weeks at a time. Portability not really too much of an issue, although I would be doing a decent amount of travel with it, although while traveling the laptop will be used for email & DVD's and almost all heavy graphics work will be done at the office. Am I better off just getting a desktop now and then purchasing a less powerful laptop to use for trips, or should I just splurge now for a very good laptop? And if I should go for the laptop, which of the ones above are the best bet? I have heard bad things about the 5100 (too much heat, not enough expandability) and the 8500 (flimsy cabinet, terrible soundcard) while the D800 seems like a very good fit, but it runs only up to 1.6 Ghz P4-M (although it seems to best the 2.4Ghz 8500 in some bench tests on CNet). Also, what if any other laptops from other companies are better than the ones from Dell listed above? thanks for your help.
  2. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    your going to be hard pressed to find a suitable laptop for your needs. CAD work and graphics both will demand more on the laptop then it can easily handle imho. my opinion is that if you go with a laptop, get something with lots of ram and cpu speed, you'll need it.
    your claiming to need a laptop, so I am assuming you travel a lot. but what I want to know is where you'll be doing your work at. if you are looking into doing work in, say your hotel room as opposed to on a plane. you may just consider picking up something like shuttle's XPC and a small LCD monitor. would be a little cheaper and more powerful for your needs without compromising the size difference much at all. just has the side effect of needing you to be by a power outlet for use (though you could use a DC->AC adapter in a car).
    anyway, feed me with some more input and I can give you some better answers. I hope this helps you out at least a little.
  3. Patrick Larkin
    Patrick Larkin Screenwriter
    May 8, 2001
    1,759
  4. Jeff Savage
    Jeff Savage Second Unit
    Aug 21, 2001
    386
    At my company we run Pro-E on the Dell Latitude C840 with the 2GHz CPU, 512MB RAM, and the Nvidia video card. It is a heavy machine but all the drives are built in. It is not as fast as a desktop but it works. We pay around $1800 for them but we do get a hefty corporate discount.
    Laters,
    Jeff
  5. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
    I second the Apple suggestion. Apple makes the very best notebooks.
  6. Tekara
    Jan 8, 2003
    783
  7. Patrick Larkin
    May 8, 2001
    1,759
  8. Camp
    Dec 3, 1999
    2,301
    No kidding...I'd almost rather carry my desktop around than a 10 pound neon green Alienware.
