Securing a Center Channel to top of TV
Discussion in 'Archived Threads 2001-2004' started by Jason GT, Jan 4, 2003.
  1. Jason GT
    Jason GT Second Unit
    Dec 12, 2002
    452
    I'm not really sure where this sort of question belongs, so...
    Does anybody have a good method of securing a center channel speaker to the top of a television set?
    I have a 27" TV and a center channel that is 17" wide and weighs about 15 lbs. It can sit on the top of the TV by itself but doesn't seem really secure, especially if I prop up the back of the speaker to angle it towards the listening position.
    Two solutions I have heard of:
    1) Tape
    2) velcro
    I'm just suspicious that the eventual heat will degrade the adhesive leaving a rather ugly mess on both the TV and speaker.
    Any other ideas?
    Thanks!
    J
  2. David Lorenzo
    David Lorenzo Stunt Coordinator
    Dec 12, 2002
    198
  3. Richard Cook
    Richard Cook Stunt Coordinator
    Aug 12, 1999
    88
    Hi there
    I use a speaker bracket of the type you can get from most DIY outlets or some HI-FI stores
    They come in different lengths so just choose the one that suits your speaker.
    Most have vertical and lateral adjustment, making the speaker easy to position
    Am I missing something? Because brackets are rarely mentioned and they seem to be the obvious solution
  4. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
    I have seen the contraption on the Crutchfield site available in stores like Bed Bath and Beyond. They make the same kind of thing for computer monitors.
    I have my center speaker angled downward also, and to prevent any sliding I have some adhesive rubber nubs attached to the bottom of the speaker. This eliminates adhesive goo on one surface at least. I check on tbe speaker every so often but I never see any shift. The most I have it angled though is about 15 degrees, propped up with a plastic video case.
  5. Jason GT
    Dec 12, 2002
    452
    Thanks for your response guys, I'll know to look for a tvtop stand.
    J
