secondary HDTV (1 Viewer)
AaronArmstrong
Hi gang,
I want to replace my old 25" tv in the basement. With a
similar size HDTV. Is there one that size? Doing a basic search I can't find one. I see the Samsung 27". Is that any good? I don't want widescreen. I have that in my living room. This set is mainly for my Xbox and Gamecube.
Any suggestions? 720p would be a nice bonus but not
necessary. I would like to be inexpensive as possible.
Under 1000?
Thanks for any info,
Aaron Armstrong
Stephen_Ri
Have you considered the Sampo SME-27FDL5? It's a 27 inch set that can do 720p, as well as accept XGA from your computer. It looks like quite a set to me. It can be found for just under $1000 online. If not, the Samsung looks like a great deal, even if it can't do 720p. At $599, it'll save you some money too.
AaronArmstrong
Boy the specs on the Sampo sound nice. But there are no
local retailers I can get it from. I'm not too keen
on ordering a TV to be delivered.
AA
Jeff Kleist
My friend got the sampo set shipped from China, worked out great. It even has both PAL and NTSC tuners so you don't have to worry about conversion artifacts,
zoobird
