"seamless" layer change players?......
Discussion in 'Playback Devices' started by DannyS, Jul 23, 2003.
  1. DannyS
    DannyS Second Unit
    Jul 9, 2001
    328
    My old sony dvp 536 has pauses that are noticeable when I play discs. I play the same discs on my Xbox and .. wha... they are not there! There "seems" to be no layer change! I know this must be down to some sort of buffer, but what "proper" players, eg: pioneer , sony, etc have these buffers? Which is the best player for a "seamless" layer change? any ideas?
  2. TerryW
    TerryW Stunt Coordinator
    Jul 25, 2000
    216
    My Apex player has this 'seamless' layer change you speak of. The reason I think that player and the XBox have this feature is because they are basically dvd-rom units which are different than most home stand-alone players. I read somewhere that you could open up my Apex unit, remove the disc drive and install it in a computer and it would work. I think the XBox is the same way. I could be wrong but this is my theory.
  3. cafink
    cafink Producer
    Apr 19, 1999
    3,043
    37
    Carl Fink
    I don't remember where I read this, so take it with a grain of salt, but I heard that the DVD specs actually prohibit a real stand-alone DVD player from using a "buffer" like you describe. Apparently, it was a result of the studios being hyper-paranoid about piracy, and not wanting DVD players to actually store any video in memory.
    Make of that what you will.
  4. Alex Prosak
    Alex Prosak Supporting Actor
    Dec 9, 2001
    773
    Some of the Denon DVD players have memory buffers. I haven't seen a layer change since I upgraded my old Sony 570 to the new Denon DVD-2900.[​IMG]
  5. Steven Simon
    Steven Simon Producer
    Sep 14, 1998
    3,276
    7
    Steven Simon
    Danny,
    This belongs in the A/V section.....
    Moving it in there now....
  6. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Both the Meridian 598 and 800 have nearly seamless layer changes -- they aren't in the "popularly priced" category though [​IMG]
  7. Jesse Blacklow
    Jesse Blacklow Cinematographer
    Oct 14, 2002
    2,049
    Superbit discs are outside the DVD specs, specifically in regards to the layer change issue (i.e. no pause). Any reasonably fast DVD-ROM will also not exhibit obvious layer change.
  8. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Denon 2900 has 16 megs of memmory.I haven't seen a layer change since I got it.Won't get anymore seamless then that.
  9. DannyS
    DannyS Second Unit
    Jul 9, 2001
    328
    does the denon 2900 uk/europe version have the same specs?
  10. Lewis Besze
    Jul 28, 1999
    3,134
  11. Ronn.W
    Ronn.W Second Unit
    Dec 16, 2002
    333
    My old Apex 600A never showed a layer change except for some discs that had notoriously bad ones. I think the Patriot was one, but don't quote me on it. My CH 500 was so bad at layer changes that it might as well have sent out a large siren and flashed a sign on the screen that said 'Layer change in progress, please stand by.' My Toshiba SD3900 doesn't show layer changes, at least none that I've noticed.
  12. WadeB
    WadeB Stunt Coordinator
    May 6, 2003
    231
    Juat another vote for the 2900. I've had mine since it first hit stores and haven't noticed a single layer change since.
    If layer changes bug you, this player is the cure.
  13. Dan Stone
    Dan Stone Stunt Coordinator
    Nov 28, 2001
    221
    I'm sincerely hoping that whatever HD-DVD standard ultimately gets adopted will have provisions for a seamless layer change (either built into the spec or via allowing for player memory buffers...doesn't matter which to me) right from the start. That's my only real gripe with the current DVD standard and also one of the primary reasons why I really like the Superbit discs.
  14. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    can anyone who owns a panasonic rp62 tell me how its layerchanges are? im hoping its not bad.
  15. Luis S
    Luis S Supporting Actor
    May 7, 2000
    637
    Rp62 has layer changes that last about a second. Not to bad but definitely not the fastest player I used. However it is far from the worst.
    Luis S
