Seamless Branching (dead?)
Discussion in 'Archived Threads 2001-2004' started by Eric Huffstutler, Feb 22, 2002.
  1. Eric Huffstutler
    Eric Huffstutler Screenwriter
    Oct 2, 1999
    1,310
    20
    Richmond, VA
    Eric Huffstutler
    Has seamless branching to fit multiple versions of a movie on one disc fallen by the wayside?
    I haven't seen it mentioned in a while and looks like a trend to issue seperate discs rather than branching.
    It worked fine on my systems so what gives?
  2. Dave H
    Dave H Producer
    Aug 13, 2000
    5,555
    186
    9,110
    I never had problems with it on my player either, but I suspect others did - especially the J6P's who own lower-end $69-100.00 players. However, I'm only making an assumption here.
  3. Ike
    Ike Screenwriter
    Jan 14, 2000
    1,672
  4. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    This question came up recently. Here is the thread, but the important part is this two-sentence post from Morgan Holly, one of the top people in the business:
  5. Jesse Skeen
    Jesse Skeen Producer
    Apr 24, 1999
    4,380
    268
    4,110
    I bought "Poison Ivy" just to check out the branching on it- it has both the theatrical and "unrated" versions, both in widescreen AND pan and scan (makes a lot more sense than the FOUR "American Pie II" discs!) I've only watched the theatrical version, but the branching is anything but seamless- at least 5 times during the movie it freezes while it goes to a different scene, along with some audio dropouts like on a layer change. Very disappointing, though they did a great job with "The Abyss" which adds, deletes and replaces a lot of scenes but the only noticable pause is the layer change.
  6. Rob T
    Rob T Screenwriter
    Aug 26, 2001
    1,987
    I think FOX did a great job with the seasmless branching on X-Men. [​IMG]
  7. Ken Seeber
    Ken Seeber Supporting Actor
    Nov 5, 1999
    787
    2
  8. Dave H
    Dave H Producer
    Aug 13, 2000
    5,555
    186
    9,110
  9. John P Grosskopf
    John P Grosskopf Second Unit
    Jan 21, 2001
    313
    I recently watched BODYSHOTS, which is seamless a branching title.
    When I chapter skipped to find the branch points, the branch points would freeze for second, & then continue (kinda like a layer change). I noted them and looked for them during playback of the feature.
    When playing back however, everything WAS seemless. Even knowing where they were, I did not see them...but, when I rewound back to go over them again, then they froze and did the layer change thing.
    Is this due to some kind of buffering the player does before it hits a branch point?
    Player was a Daewoo 5700.
  10. Bryant Frazer
    Bryant Frazer Stunt Coordinator
    Dec 1, 1998
    121
    What Poison Ivy does is not seamless branching. When I've asked DVD experts about it, I've been told that it's a "nonseamless multistory technique." I'm not sure about Body Shots.
    Seamless branching, as seen on The Abyss requires a powerful authoring system to support it and, as I understand it, quite a bit of grunt work on the part of the DVD-authoring personnel. It also breaks at least a few players out there, which makes it a pain in the ass for studios.
    As I understand it, this is why pan-and-scan-on-the-fly has never been widely implemented: In tests, there are too many players out there that just can't keep up with the complicated instructions.
    -bf-
  11. Jon Robertson
    Jon Robertson Screenwriter
    May 19, 2001
    1,568
    Dressed to Kill is as lovely and seamless as you can get, and that was made in August of last year. As far as I can tell, that was the last seamless-branching title released.
  12. TheoGB
    TheoGB Screenwriter
    Jun 18, 2001
    1,744
  13. AaronMK
    AaronMK Supporting Actor
    Oct 30, 1999
    768
    Orlando, FL
    Aaron Karp
    T2:UE, Independence Day, the Abyss, and Stargate didn't have any pauses at the branch points on my player (low end sony, two years old).
    Did these use seamless or extended branching? Also, what is the difference?
  14. Iain Jackson
    Iain Jackson Second Unit
    Nov 22, 2001
    371
    T2, The Abyss and Independence Day all have seamless branching. I'm not sure about Stargate. Also, The Rocky Horror Picture Show uses seamless branching, as well as the Die Hard Five Star edition (I think).
    Seamless branching means just that - there are no pauses, and the branch points are seamless. Extended branching generally does have pauses of some sort. I'm not sure, but as far as I know, this is because in seamless branching, the extra content is actually stored in the main data stream with the rest of the film, whereas extended branching has the extra content stored at the end of the film. This results in the pauses when the laser has to relocate to a different part of the disc.
    The key difference is that extended branching is easier for players to handle,and is easier to program when authoring the disc. Seamless branching can often confuse some players, and is complicated to program.
    Of course, I'm not an expert, so don't quote me on anything...
  15. Daniel Kikin
    Daniel Kikin Screenwriter
    Apr 3, 2001
    1,620
  16. mark_d
    mark_d Second Unit
    Dec 4, 2000
    258
    Doesn't Star Wars I:TPM use seamless branching for a multi language capable opening crawl?
    Mark
  17. Michael Reuben
    Feb 12, 1998
    21,763
    2
  18. LukeB
    LukeB Cinematographer
    Apr 26, 2000
    2,178
    Actually, I do believe that the credits in different languages thing utilizes seamless branching. Disney does this with most of their titles and it involves going to a different set of credits automatically. Why wouldn't this be considered seamless branching, since angles are not utilized?
  19. PhilipG
    PhilipG Cinematographer
    Jan 13, 2000
    2,002
    Isn't SB used on Columbia's SB (superbits) discs? Those discs have the quickest, most unnoticeable layer changes of any of the RSDL discs in my collection. [​IMG]
  20. Damin J Toell
    Damin J Toell Producer
    Mar 7, 2001
    3,762
    6
    Brooklyn, NY
    Damin J. Toell
