Sealing an EBS Shiva to stop farts.
Discussion in 'Archived Threads 2001-2004' started by Stephen Dodds, Jan 2, 2003.
  1. Stephen Dodds
    Stephen Dodds Second Unit
    Aug 29, 1998
    354
    My EBS aligned Shiva farts on very deep bass. It isn't really volume related but is, I assume, the driver unloading. So I want more depth.
    So I'm thinking of blocking the vent to make a sealed sub, and possibly swapping out the Shiva for an Adire DPL12. I'd EQ or L/R transform.
    Anone tried this or can think of a reason I'm being dumb?
    Cheers
    Steve
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,722
    463
    Nah, give it a shot, with room gain, the low end performance might allow for a sealed Shiva sub to work for in achieving your performance goals.
    I usually stuff port holes with Nerf products (a Nerf football works well in a 4" wide port).
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    It's easy enough to try. I have directly compared an EBS Shiva and DPL-12 (5ft^3, 18Hz Fb) to the same sealed drivers and there's no comparison as far as depth and dynamics, I much prefer the vented in almost all instances. The DPL-12, however, is an excellent sealed driver, much better than Shiva I feel, and will do about as deep as bass goes with a bit of room gain. Of course, it's excursion limited down low, unlike the reflex design, so won't go as loud.
    What amp are you using with your Shiva EBS?
