Sealed vs Vented cubes in an HT
Discussion in 'Archived Threads 2001-2004' started by NathanP, Sep 29, 2001.
  1. NathanP
    NathanP Supporting Actor
    Aug 13, 2001
    841
    Guys,
    I'm building a new sub for my HT, I'm going to build a cube.
    I've heard that for HT, Vented is better, but for music, sealed is..
    What do you guys think?
    Get back with me,
    Nathan
    "Fascinating Captian"
    --Spock
    Visit www.speedemenu.com
  2. TerryC
    TerryC Stunt Coordinator
    Oct 19, 1999
    218
    100% true, its all a compromise to what you want. I recently read something where a very respected speaker designer mentioned something along the lines of take 10 piano manufacturers and listen to a model from each, they will all sound different but nobody will say they don't sound like piano's and who's to say which is better?
    This is how I feel about "good" subs designs, each has its strong points but each will generally perform it's duty and you will be 100% happy. If you listen to mostly music you may want go sealed but if home theater is largely in the mix ported will likely play louder in the lowest octaves.
    Either way I'm sure you will be 100% happy with whichever you decide on.
  3. NathanP
    Aug 13, 2001
    841
    Anyone else?
    I would really like some more!
    --Spock
  4. Isaac C
    Isaac C Stunt Coordinator
    Aug 1, 2000
    140
    Correct me if I'm wrong, it sound like you're not prepared to let go of the vented-box side of your decision just yet [​IMG] In that case, I'd suggest the SBB4 alignment. As you might already know, it has the best vented-box transient response (trading off a bit of bass extension, of course) [​IMG]
    What do you think?
    Isaac
    Subwoofer Simulator: http://www.geocities.com/f4ier/subsim.htm
    Factor Conversion Tool: http://www.geocities.com/f4ier/fct.htm
  5. Chris_Brunhaver
    Dec 27, 2000
    20
    From what I understand, cubes really aren't the best shapes for speaker enclosures. Actually, they are about the worst are far as creating standing waves in the enclosure.
    -Chris
  6. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Right, but if the cube's dims are small enough that the potential standing waves are higher than the sub's BW, it doesn't matter. For instance a 2ft i.d. cube has its first mode at c/2L, or 1130/2*2 = 282.5Hz, well outside the audible BW of an 80Hz/4th order XO.
    GM
    Loud is beautiful, if it's clean
