Sealed Tempest? (1 Viewer)
Adam Gutierrez
I am a current owner of a Shiva in a SBB4 ported cabinet. I have enjoyed it for about a year now, but now I am wanting more. I just ordered 2 Tempests from Dan and am considering two seperate sealed boxes 122 liters net. I dont really care for the boomy type sound I am getting from my current sub but I love the increased extension I get with the ported box, I am looking for a tighter sound without giving up too much extension. I have a very small theater approx 13 feet by 13 feet. I have a Mackie M1400i for power. I have a stage with only about 18 inches in height to work with, about the same depth wise, I can go as wide as I need to for proper box volume. I was considering 2 sealed mid Q enclosures. Will I be dissapointed with the extension of these two 15's in sealed boxes? Passive radiators are not an option due to limited funds. Before I started enclosure construction I wanted to get some feedback.
BTW, my theater is used for virtually 100% movies, almost no music.
Adam
Jack Gilvey
Download LspCAd from Adire and get an idea of the extension in your room. With two Tempests and decent power available, you could consider the Linkwitz transform to have extension as low as you'd like.
Adam Gutierrez
I have lspCAD, I guess what I am asking is if anyone has built a sealed Tempest, how they liked it? The punch, extension, overall tightness. I realize room size has alot to do with it, I just wanted some general feedback about sealed Tempests.
Adam
Brian Bunge
Didn't TerryC build a sealed Tempest enclosure and compare it to a ported Tempest enclosure? Or did he compare the sealed enclosure with his MASS sub? He posted response curves and everything.
Brian
Jack Gilvey
The folks who've done sealed Tempests seem quite enamored of them. Try a search here or on hometheatertalk.com. I've had one in an infinite baffle, and it's beyond reproach. Your aural descriptors, punch, extension, overall tightness, will be determined by your box and room. Folks usually associate something around a Qtc of .707 with "punch", although a lower Qtc value will have greater extension and transient response (tightness). In general, a sealed Tempest will sound like you design it to sound, since the Tempest is so adaptable.
Fred Seger
I have a sealed tempest in a 130l box. Overall it's a very good sub, but if your only using it for HT you'll be disappointed in the extension. IMO. Unless you do like Jack suggested and implement a Linkwitz transform, or maybe an equalizer to provide the greater extension.
Adam Gutierrez
Ok, I give up.... I have 2 Tempests on the way and dont have a clue what type of enclosure to build. I guess I just want too many different things. Tight, low, and loud. Sounds so simple considering 2 Tempests, my small room size (13x13) and available power (Mackie M1400i).
Julian Data
Adam
I have you downloaded the white paper for Tempest per applications? You need to decide what you goals are.
Fred Seger
If your room is sealed off from other rooms good enough(doors), then maybe room gain will compensate enough on the low end. I'd say go ahead with the 2 sealed boxes like you mentioned, and if your not happy with the results then add an equalizer later.
I'm sure you'll like the results from the upgrade either way.
Jack Gilvey
Just to add another observation (as if you needed one
), don't judge all vented subs/alignments by your experience with the SBB4. That one's mainly geared toward HT high-output. A Tempest in a large, low-tuned cabinet like Pat's latest can sound tight and controlled while having usable extension to the teens.
Chris_Campbell
Chris
I've got a tempest in a 10 cube ported box tuned to 18 hz, and it sounds terrific. I'm actually powering it with the same mackie you have. Currently I'm building a 3 cube box (with 16 oz poly/cube) for use with a sealed tempest in my car. This makes for a Qtc of around .71. It will be getting around 800 watts instead of your 1400, but I'll certainly post a review as soon as its in. I'm painting it today and tomorrow it should be ready.
Richard Greene
I responded to this post on the Home Theater Talk website and forgot to add that your small room
should provide approximately 12dB per octave room gain below your lowest frequency standing wave (axial mode) which would be at roughly 566/13= 44Hz.
The room gain should offset the low frequency roll-off of the Tempest in a sealed enclosure. If you use a ported design in such a small room, you will have excessive output at 20Hz.
The probability of obtaining reasonably smooth bass frequency response in a small square room like yours
is slim to none without the use of an equalizer.
Your "boom" is from the room, not from your Shiva sub.
Jack Gilvey
Depends on how "tight" the room is. I've got a room of similar dimensions, but get nowhere near that much gain.
zukz15
