SCSI help!
Discussion in 'Archived Threads 2001-2004' started by Jeff Kleist, Mar 19, 2002.
  1. Jeff Kleist
    Dec 4, 1999
    11,267
    I have an Iomega Buz, which has a built in Advantec UltraSCSI adapter. Now my scanner is my only SCSI device and it used to work fine. The card reports back fine on boot, but if I have the scanner plugged in I get "Error 0x15". Windows device manager reports the card having trouble even with a driver reinstallation(whether something is plugged in or not). Is the card hosed?
    Yes, I tried another slot, it worked fine the last time I hauled out the scanner 2 years ago.
  2. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    Double check the SCSI termination and also the IDs. Only the last device should be terminated and each must have a unique ID#.
    Pete
  3. Jeff Kleist
    Dec 4, 1999
    11,267
    Only 1 device, it's terminated and I tried switching the ID
