screws and glue without clamps, will it be ok ?
Discussion in 'Archived Threads 2001-2004' started by Jones_Rush, Jun 22, 2001.
  1. Jones_Rush
    Jones_Rush Stunt Coordinator
    Jan 19, 2001
    198
    I am going to start building my first sub on sunday,
    The problem is that I have no clamps at all.
    My plan is as follows:
    1) tell the carpenter to cut all the necessary boards.
    2) I will also tell him to make all the holes for the
    screws.
    3) I will take the boards to my home, glue them together,
    and then use the screws to make it hold. (Well, It's a
    DIY sub, I must do something on my own...)
    Will this work ? can I get away without using clamps this way ?. How much time will the screws will have to be inside the MDF before ejecting them out ?.
    btw, the sub is going to be a sealed 3 c/f shiva.
  2. Shade Watson
    Shade Watson Stunt Coordinator
    Jan 24, 2001
    135
    Jones,
    Thats the way I built mine, and I own clamps. I find useing screws faster and easier. Why do you want to take them out when you are done?
  3. Kevin Liedtke
    Jul 10, 2000
    27
    Thats the method I used (screws and glue) on my Kit81s. The only time it split the MDF was the first screw I put in and didn't make a pilot hole. Everyone after that went in with out spliting the wood. I found the method to be pretty easy.
    -Kevin Liedtke
  4. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
  5. Jones_Rush
    Jan 19, 2001
    198
    quote: Why do you want to take them out when you are done?
    [/quote]
    Well, I read somewhere that if you don't get the screws outside the MDF after the glue dries, after some time the screws can damage the MDF or the sub's covering somehow.
    I read that if you need to use screws with MDF, you should do it only with T-nuts, but T-nuts are not an option in this situation.
    Have you heard anything about this?, or have I just read wrong ?, It will be a lot easier to leave the screws inside the MDF rather than to take them out, fill the holes, and sand them.
  6. Dan_D
    Dan_D Stunt Coordinator
    Jun 18, 2001
    98
    Ive been building car audio boxes for years and have always used 3/4" MDF w/ 1.5" particle board screws and liquid nails. always works great. im in the process of making a home sub enclosure now and am doing the same thing. Just be sure to predrill and countersink every hole. [​IMG]
  7. Jones_Rush
    Jan 19, 2001
    198
    What is a liquid nail ?
  8. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,777
    492
    9,110
  9. Jones_Rush
    Jan 19, 2001
    198
    Can anyone give me a rough approximation of how many screws will I have to use in order for the box to hold well.
  10. SteveMc
    SteveMc Stunt Coordinator
    Feb 3, 2001
    230
    110
  11. Kevin Liedtke
    Jul 10, 2000
    27
    You really only need enough screws to make sure the sides are tight together. Im sure one box would be plenty for your construction.
    -Kevin Liedtke
  12. Dennis Kindig
    Dec 26, 1999
    43
    Hands down, the biggest time-saver I have ever used for enclosure construction is an air-powered brad gun. It completely eliminated clamping, drilling pilot holes, time spent getting that perfect edge alignment, reduced hole-filling requirements, etc.
    If you want to get exact edge aligment without pulling your hair out, throw a biscuit-jointer into the mix. The glue really does most of the work in maintaining the integrity of the enclosure. If good resin-glue is used, the MDF should give before the joint does.
    Dennis
  13. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    I'm going to be different here (strength of the forum) and tell you that I have built many speakers, from monitor (bookshelf) size to towers, and I do not use screws. If your saw cuts are accurate so the MDF surfaces mate well, good old carpenter's glue and clamps work great. Screws are an unnecessary time-consuming item. Lots of holes to drill while you hold the wood in alignment, then you have to countersink the holes. Afterwards, you have to go back and fill the holes, then sand the filler flush with the wood surface. The glue joint will be stronger than the MDF itself, so screws do not add joint strength. Years ago, I used lots of screws and finally had to think "outside the box" and experiment with no screws. Now I save time and money by not using screws. I recommend glue and clamps. As Dennis said, an alternative, if you want to invest in it, is an air-powered brad gun. I would still use my band clamps to hold the enclosure square.
  14. Patrick Sun
    Jun 30, 1999
    38,777
    492
    9,110
    Add me to the "Glue and Clamp" camp. I just finished my rear speakers (see the SunTwo's thread), and again, I used just Titebond II and clamp pressure to put them together.
    PatCave; HT Pix; Gear; DIY Mains; DIY CC; Sunosub I + II + III; DVDs; LDs
  15. Ken Cline
    Ken Cline Stunt Coordinator
    Jun 30, 1997
    99
    Well, I like using screws and glue. To me clamps are cumbersome(especially when trying to align two corners), and I do own clamps. I've tried the clamp method, air nailer method and screw method. It doesn't take me that long to predrill the holes.
    I use 2 miter clamps at each corner and predrill the required holes. This makes perfect alignments - easily.
    Just my 2 cents
    Ken Cline - Home Theater Fanatic
    [email protected]
    Friends Don't Let Friends Watch Crap!
    www.dvdtracker.com/~kencline.asp
  16. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    I really like using glue and clamps along with a biscuit joiner! The biscuits really help with alignment, although a slightly warped piece of MDF can throw things off very slightly. But sanding can take care of that!
    I really would like to try those band clamps as well. Hank, don't you use those band clamps that MCLS (or is it MLCS) sells?
    Brian
  17. BrianW
    BrianW Cinematographer
    Jan 30, 1999
    2,563
    38
    Brian
  18. Hank Frankenberg
    Oct 13, 1998
    2,573
  19. BrianW
    Jan 30, 1999
    2,563
    38
    Brian
    Thanks for clarifying, Hank. Sorry for mischaracterizing what you were trying to say.
    I'm always amazed at the expertise displayed on the HTF, regardless of the topic. But, heck, we could start a whole new forum with the woodworking talent we have here! What an awesome group we have!
    Don't ever take woodworking lessons from a guy named "Nubby."
  20. David A. Frattaroli
    David A. Frattaroli Stunt Coordinator
    May 10, 1999
    173
    I also like Gorilla Glue. Great stuff for wood and MDF. I prefer it to yellow glue. I think they have it atwww.rockler.com.
