JamesP
Grip
- Apr 28, 2004
I just picked up a used Infocus 4800 with 800 hours on it for $500 CAD, I was planning and still am planning on going with a Panasonic 900. The problem is that the screen size that the Infocus puts out is alot smaller then the Panasonic, and I am at the stage where I am about to get a screen.
Do I:
1. Get a slab of MDF and paint it, and then get a proper screen when I get the Panasonic? (8-12 months off probably)
2. Figure out the screen size of the panasonic and plan for that?
3. Get a proper screen now for the infocus, and then get another one when I get the panasonic?
I am a little squeezed for budget, but not too bad.
If I go with option 1, what colour to paint the MDF for the best results?
Do I:
