Screen door effect question?
Discussion in 'Archived Threads 2001-2004' started by DaveJJ, Nov 15, 2002.
  1. DaveJJ
    DaveJJ Stunt Coordinator
    Jan 20, 1999
    79
    I am planning on using a LCD projector with a special component to VGA cable converter connected to a JVC progressive scan DVD player. Will I still see the screen door effect(SDE)...??? Thanks for any comments!
    DaveJJ
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    Yes, depending on how far away from the screen you sit, the size of the screen, the type of LCD projector (MLA or not), the resolution of the LCD projector, and your own sensitivity to it.
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Tell us the model of LCD projector you are going to use and how far from the screen you will be sitting.
  4. DaveJJ
    Jan 20, 1999
    79
    My unit is a LVP-X100A Super-XGA LCD projector which is made by Mitsubishi Electronics. The resolution is True 1024 x 768 with about 750 TV lines and 16 millions colors. The brightness is average with 600 ANSI lumens. Contrast ratio is 200:1. The Aspect Ratio is 4:3 and is capable of projecting a picture that is over 300 inches measured diagonal. The projector has a built-in line doubler. It has input connections for S-video and RGB(vga). My viewing room is a combination dining /living room. So I have plenty of space for viewing DVD movies in widescreen format. The screen size is a matte white Da-Lite 72"/96".
    DaveJJ
  5. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    1024x768. Ok, you will be able to see screen door effect if you are close to the screen, obviously. The recommended minimum seating distance from that size of screen would be 12ft and at that distance, you should not really be able to make out the pixel structure. How far are you planning to sit?
  6. DaveJJ
    Jan 20, 1999
    79
    Ok Neil, thanks for the info. My seating will be about 40 to 45 feet from the screen. Will I get a improved picture with my JVC progressive scan DVD player using component video outputs?
    DaveJJ
  7. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    Are you sure you will be able to see the screen from 40-45' [​IMG]
  8. DaveJJ
    Jan 20, 1999
    79
    Sorry about Neil, I met to type 20-25' from the screen. My room is only 30' long. My second question was will I see a improved picture quality with component video over my current setup with S-video cable?
    DaveJJ
  9. Gabriel_Lam
    Mar 7, 2002
    1,402
    Wow, that's still an enormous distance for that size screen. I doubt you'll see the screendoor effect at that distance with that screen size. Your LCD projector is a NON-MLA type, and an early one at that. The fill ratio is somewhere around 60% or so:
    [​IMG]
    However, at your distances, it really shouldn't be apparent.
  10. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
  11. Dennis Reno
    Dennis Reno Supporting Actor
    Jun 30, 1997
    862
    Dave,
    I use a Sanyo PLV-60HT and a Stewart GrayHawk 100" diag (49" x 87"). My main seating is approx. 13.5' from the screen. The screen door effect is not noticeable 99% of the time. I can see it only if I focus on a particularly bright area or watch from inside of 12' from the screen.
    With a 120" diag 4:3 screen I would highly doubt that the screen door effect would be visible from 20+ feet. If it is the USAF needs you!
  12. Todd_B
    Todd_B Second Unit
    Jul 16, 2000
    381
    You could always defocus slightly if it is a problem.
    Todd B
