Darren James
- Oct 21, 2004
I'd like some advice regarding determining a screen aspect ratio. I've searched for and read many posts but cannot quite find the answer to my confusion.
I am using an HTPC (MSI Mega PC) with an All-in-Wonder 7500 outputting to an NEC LT240K projector. I use PowerDVD to watch DVDs and ATI Eazylook for TV. I intend to use Meedio in the future for both. Currently I project onto a wall.
I am now in the market for a screen and am considering one of the electric Elite 100" models from Tigerdirect.ca. There is a 4:3 version and a 16:9 version...and this is my dilemma.
I have read posts that suggest it's a personal decision based on how much widescreen material you view versus TV (4:3) material. However, based on the equipment I have, I wonder if technically I should go with one aspect ratio over the other?
I believe my PJ is a native 4:3 model. My PC outputs 4:3 to the PJ. PowerDVD/Meedio add the black bars to the top and bottom of the screen when viewing a widescreen DVD.
The PJ has four aspect ratio options - 4:3, Letterbox, Widescreen and Cropped. When viewing a widescreen DVD, 4:3 and Letterbox view the same, Widescreen shows the same picture but appears to be vertically squashed and Cropped seems to cut the picture (so I think cropped is out).
Whichever aspect ratio I choose, the PJ seems to be projecting a 4:3 rectangle of light. I am assuming that this is the case because the input is coming from my PC. I have tried to play with the output resolution on the video card but with little success. So does this mean that my PC can only output a 4:3 image?
If the PC can only output a 4:3 image, and the PJ can only ever project a 4:3 image based on my input, I assume I will always have the black bands projected onto my screen?
If this is the case, then based on what I've read my dilemma comes down to a question of personal preference, masking the screen and the distance of the PJ from the screen?
TIA for any answers, sorry for the long post...just wanted to demonstrate that I had tried thinking about this before posting.
Edit...I've tried Powerstrip, Rage3DTweak and changing the resolution settings in PowerDVD...with no success...must be doing something wrong?
Darren
Darren
