Now I have watch them to make sure they aren't messed up.Hate to say, but you should always watch purchased materials within your return window.
My returns although infrequent are running 50% obviously scratched (to the point of affecting playback) and 50% looks perfect but apparently has a low level production error.
In short, you never can tell.
it drives me nuts when I get new discs that have scratches on themYou know, I didn't really think this happened much.
But today I opened a new copy of 'The Right Stuff' SE and thought to look at the discs for once.
Disc 1 was perfect, but Disc 2 has a small cluster of 10 micro scratches.
I got this one free through a mail-in offer, wonder if someone returned it...
From what I can recall, that would be certain doom for a DVD. Cd's are designed that the plastic coating on the play side is more protective than the printed side. I'm sure DVDs are made the same way.So...I guess it's better that the DVD-producing outfits spend thousands of extra dollars per year on replacing scratched discs (on data side) that won't play (or that skip to high heaven)??
Seems to me the definite lesser of the two evils is certainly to flip the disc, and have the disc shipped data side UP, to prevent damage to the most important side of the item.
Do you not agree that this would be best?
From what I can recall, that would be certain doom for a DVD. Cd's are designed that the plastic coating on the play side is more protective than the printed side. I'm sure DVDs are made the same way.No they're not. Think of all DVDs (even the single sided discs) as being like two CDs glued back to back. The data is nearly in the very middle of the sandwich.
The problem with scratches is a relative thing. DVDs have much higher density than a CD, so much more can be corrupted by a scratch. Also, DVDs have compressed data so the corruption is more widespread than just a quick pop or skip on a CD. It doesn't seem to matter that DVD has stronger error correction than CD.
Hate to say, but you should always watch purchased materials within your return window.With season sets this can be a bit problematic. The West Wing arrived and the first disc was unplayable so we were able to get that returned okay, but we just got to the last disc of Season 1 of Angel and discovered that it is unplayable. So, what do we do now?
Options:
1) Contact FOX - has anyone ever done that? Would they do anything?
2) Attempt to exchange it at some store. Perhaps wait until after Christmas?
3) Any other ideas?
Neil
