scrambled picture on DVD
Discussion in 'Playback Devices' started by Sathyan, Apr 13, 2004.
  1. Sathyan
    Sathyan Second Unit
    Jun 17, 2002
    298
    I'm trying to help my friend use his DVD player [1]. The TV is used for both audio and video. First we tried connecting the a/v cable from the DVD a/v out to the TV's video2 in. There was sound but no picture. Tried two known-good DVDs (Das Boot; The Who at RAH). At first I thought the video cable was bad so tried it with the cable box and it worked fine there. So maybe the composite video out on the DVD player isn't working, so rounded up a few more video cables and hooked up component video (after disconnecting the composite). Now we had something on the screen but the actual video was very dark, it was jumping around, it was displayed double (split left and right), large red "v"'s moved across the screen.
    Neither of us has an s-video to try that.
    All the TV settings appear fine (and look correct when watching CATV).
    Can't change menu-based DVD settings as picture won't stay still enough to read them.
    Any ideas?
    thanks
    Sathyan
    [1] DVD player: Polaroid DVC 2000 http://www.polaroidelectronics.com/p...DVC%202000.asp
    TV: Toshiba 20AF42 http://www.tacp.toshiba.com/televisi...p?model=20af43
  2. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    Sounds like you may have crossed the component cables; i.e., hooked "red" out from the DVD player to "blue" in on the TV, etc.
  3. Nathan Stohler
    Nathan Stohler Second Unit
    Jan 17, 2004
    329
    As far as the component video goes, I've seen the scrambled screen before when one of my component cables was loose. Make sure the connection is good and snug, and make sure you have the cables connected correctly, as Jeff suggested.
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    TV does not appear to be HD ready, and the player may be set to progressive, in which case the TV cannot display the image. Hopefully, you can set the player to interlaced somewhere other than the OSD setup or you may have a big problem.
  5. ross ish
    ross ish Stunt Coordinator
    Nov 18, 2002
    163
    make sure you do not have the dvd player set to pal, set to ntsc
  6. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Yes I'd say the player is setup for progressive and you are using an analog (interlaced only) TV. Look for a switch on the back of the DVD player to force interlaced mode. If there is none, you would need to connect to an HDTV to access the player's setup menu to select interlaced.
  7. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
  8. Ken_B
    Ken_B Auditioning
    Apr 17, 2004
    4
    Yep. TV spec sheet mentions "interlaced" but not "progressive."
    There should be a setting on the DVD player (physical or in on-screen set-up routine), or it may have two different component video output jacks (one marked "Progressive"). If the DVD player's only component video output is progressive the next best thing would be S-Video. And many DVD players have settings to designate the output.
    I'd agree with the suggestion of using the composite video (yellow) jack until you get the player properly configured for your set-up.
  9. Sathyan
    Sathyan Second Unit
    Jun 17, 2002
    298
    Ok, its fixed now.
    One of the component video cables was wrong and it was on progressive.
    They put a button to switch between interlaced and progressive on the remote (labeled "i/p") which apparently had been pressed at some point.
