Science behind the bose wave radio
Discussion in 'Speakers & Subwoofers' started by MichaelBryant, Dec 12, 2003.
  1. MichaelBryant
    MichaelBryant Stunt Coordinator
    Feb 23, 2003
    76
    I would love for someone to explain the "science" behind the Bose Wave Radio. Bose claims the sound from the speakers travels through a tunnel inside the radio making the sound "fuller". I'm no audiophile but considering the speakers are facing in the opposite direction of the tunnel how on earth is the sound going to travel through them?
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Brett Andrew DiMichele
    Michael,
    The way the Wave Radio works is quite simple really, it is
    nothing revolutionary by any means.
    The Bose Wave Radio uses two drivers to produce the Stereo
    Sound Field one of the drivers is a 3" Paper Wideband
    driver and the other is a 4" paper midrange if I recall
    correctly.
    Every speaker "driver" has a front and a back wave. The
    sound you hear from the front of a driver is only half of
    the air movement the driver produces. What Bose did was to
    take the 4" driver and build a folded transmission line
    behind it.. What does this do? The back wave of the driver
    is channeled through that tube that is folded up inside the
    Wave Radio enclosure and it reverberates to create lower
    frequency sound without the need for a much larger woofer.
    I think the setup is also called a Quarter Wave Pipe. Bose
    also used this "technology" in the 3rd Generation Mazda RX7
    where they had tubes running all through the back of the car
    with small drivers to produce lower frequencies.
    As with anything there are trade-off's and this technology
    is not without them.. The lowest frequency is still determined
    by the length and size of the tube plus the drivers ability
    to generate the air to move..
    [​IMG]
    As you can see on the original Wave system it has a
    specific low frequency driver coupled with the Acoustic
    Wave Guide. The Wave Radio just uses one of the stereo
    drivers to generate the low frequency information which
    dare I say is cheesy. In a "Stereo" configuration you
    typicaly want the same exact drivers on each side yet
    the Wave Radio has two completely different drivers.
  3. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
  4. Chris Xolotl
    Chris Xolotl Second Unit
    Jun 28, 2001
    482
    Neat
  5. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    Neat.
    In theory, it is cool, but we all know the truth...
    FYI. The Bose Wave Radio (the $500 one) is MONO, not stereo.
    Would you pay $500 for a mono system?
  6. Brett DiMichele
    Sep 30, 2001
    3,181
  7. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    Brett,
    the image you posted shows 3 drivers - could it be some sort of 2.1 system?
  8. MichaelBryant
    Feb 23, 2003
    76
    Thanks Brett. Do you have any idea why Boses uses different types of drivers on each side of the unit? The idea behind the "wave guide" system sounds interesting but also looks like a very cheap and easy to manufacture audio "technology". If I understand correctly all Bose does is place some small, inexpensive drivers in front of plastic tunnels (in place of larger speakers) and that is the remarkable science that justifies a $1200.00 price tag.
  9. Brett DiMichele
    Sep 30, 2001
    3,181
    Michael,
    The wave clock radio uses 2 speakers total. One speaker
    is to produce higher frequencies and the other is located
    in the wave guide to do the low frequency this setup is not
    stereo.
    The "wave radio" on the other hand uses two wideband drivers
    to do the upper and midrange frequencies while it has a
    larger centrally mounted driver (see image above) coupled
    to the wave guide to produce low frequency.
