Ken
- Dec 7, 2003
My cable co. came over with the intention of installing a high def box. Unfortunately, at the moment, because of other factors related to my home theater, it cant be done.
However, my TV reception is significantly better with the 4200HD box vs. the previous 4200 (non-HD). The installer left the HD box for me to experiment with.
My problem basically comes down to the question: can I use the 4200HD without the high-def output jacks? I am using the S-video output to my Denon receiver. However, I cannot access a number of features on the remote such as Info, Guide, Settings. Also, pressing the Guide and Info bottons simultaneously should bring up a settings screen but it does not.
Can anyone help or direct me to someplace to get an answer?
thanks
Ken
thanks
Ken
