School Me On PAL
Discussion in 'DVD' started by Bruce Wang, Apr 7, 2004.
  1. Bruce Wang
    Bruce Wang Auditioning
    Apr 6, 2004
    3
    Hello all. This is my first time posting. I have a DVD player that says it has a PAL convertor. Is that all I need to play PAL DVD's? Will the DVD play normal? Any help is appreciated.
  2. Hendrik
    Hendrik Supporting Actor
    Oct 23, 1998
    595
    ...make...?... model...?...
    (if you want help, you have to be a little bit more forthcoming with information, yourself...!...)
    . . . [​IMG] . . .
  3. Bruce Wang
    Apr 6, 2004
    3
    I have a Koss KD305.
  4. Greg_D_R
    Greg_D_R Stunt Coordinator
    Mar 11, 2001
    221
    4
    A quick Google search brings up a couple of forum posts confirming that the Koss KD305 does indeed convert PAL to NTSC, so yes, it is all you will need to play PAL discs. "You've taken your first step into a larger world", or words to that effect.
  5. Erik G. Lund
    Erik G. Lund Extra
    Apr 5, 2004
    18
    The PAL converter will NOT, on its own, allow the unit to play R2 DVD's - if the unit is R1.
    What's the case?
