Jason Bosch
- Dec 13, 2002
Hey everybody. I was just curious what you guys thought about these drivers. Specifically the D2905/9900 1" Textile Dome Tweeter, the 15S/8530K-01 5-1/2" Woofer, and the 18W8531G-00 7" Woofer. I was thinking that I might be able to make some really fantastic speakers from these. I was looking into using the tweeters and the 7" woofers. To make some killer 2-way Towers. On the design of those they would basically be about 4 feet tall, 8 inches wide, and 10 inches deep or so. Made from 3/4 or 1" MDF and covered in a nice rosewood veneer. They would be setup up with the tweeter up top and the woofer right below it in a seperate enclosure aprox. 10 inches tall with the rest of the tower really just serving as a stand, and maybe to help make the bass more solid. They'd probably have a small port exiting the rear. For the rest of my system I would make 3 2-way bookshelf speakers using the same tweeters and the 5-1/2" woofers. 1 for the center channel and 2 for the surrounds. I don't think I'd be able to make a horizontal center because If I used 2 woofers it would drop the impedance to 4 ohms and wouldn't match. Plus I've heard bad things about those kinds of center matching with mains anyways. So anyways I just wanted to see if anyone else thought this would be relativly feasable to do. The main problem I see with this is getting good enough crossovers to do the system justice, as I have no clue how to make those. I know that Adire does them for like $250 each... seems like alot to me. And I don't know how well just some $20 dollar ones from Parts Express would do. Beyond that I know i'll have to read the loudspeaker cookbook, and get a piece of software to help me in designing perfect enclosures for these. If anyone has any advice or opinions on this please reply. Thanks everyone
