Saving Dvd Options
Discussion in 'Archived Threads 2001-2004' started by Ryan Wetenhall, Jan 29, 2003.
  1. Ryan Wetenhall
    Nov 17, 2002
    24
    Hey, how do I save dvd options on my playstation 2? Like on my ps2 I want to save some settings that I changed by pressing select, how do I save those settings?, I pressed select during the dvd and changed the audio output options so I can use dts, but I want to save it to my memory card so that I dont have to change it every time I boot up a dvd.
  2. Jeff_Standley
    Jeff_Standley Supporting Actor
    May 17, 2002
    905
    You have to go into the tool box on the transparent menu on the PS2. Switch the output to Digital and DTS on. I did that and the saving was automatic.
  3. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    There was some unintuitive step in saving the settings -I think it was that after changing the settings, power off the PS2 while there is a dvd in the PS2.
    -Dave
  4. DaveGTP
    DaveGTP Cinematographer
    Jul 24, 2002
    2,096
    After 2 years of dealing with the Parental DVD protection level set to like rated G (my g/f did it when she set it up), I finally got the energy to track this down a month or 2 back.
    After you have the settings the way you want, eject the DVD tray and then close it again. This saves the settings. VERY unintuitive.
