sattelite hdtv in apartments
Discussion in 'Archived Threads 2001-2004' started by Chris Strasz, Nov 8, 2002.
  1. Chris Strasz
    Chris Strasz Stunt Coordinator
    Sep 25, 2002
    66
    First, sorry if I have this in the wrong thread - I went to check if there was another forum and the closest I found was hdtv programming (but that seemed catered to specific programming.)
    Anyways, I currently am going to be moving into an apartment and I believe that they have direct tv like my current one. I just purchased an hdtv set which i'm going to get when i move into the new apartment and was curious to know how typical is it to have direct tv hdtv broadcasting in apartments?
    From my experience at the current apartment, all residents share one large dish that is on the property (or something along those lines). From reading directv's site it seems like you need a separate dish for hdtv so I'm going to go out on a limb here and assume that most apartment complexes didn't invest in an extra dish for hdtv correct? [​IMG]
    (Edit: Just realized I spelt the subject wrong - doh!)
    If this is the case I'm just going to go with time warner cable as that's also available there.
  2. Kamal_K
    Kamal_K Stunt Coordinator
    Oct 22, 2002
    58
    yes you do need a directv hd receiver to get it.
  3. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    I'd try posting in Audio/Video Sources.
    Jan
