Satellite signal help (1 Viewer)
eric_thr
Grip
I have an approximately 8 month old oval direct tv dish and I am starting to have problems with signal reception. The strange part is that I have no problem until it rains and then the 101 satellite goes out completely, but I still have a picture from the 119. The problem continues even as the sky clears completely. Do some LNBs have a short life span? What else should I look at?
Thanks.
Westly T
Have you checked all the cable connections and switches (If they have them)? Sounds like you are getting water somewhere it shouldn't be.
Jeff D
What's the "clear weather" signal strength for transponders on LNB 2? How about LNB1? If they are low, then clouds/rain can surely lower the signal level and cause you problems.
Also did you mount the dish yourself or have a pro do it? I'm about to go re-adjust my aim this weekend.
Gali
