satellite internet service
Discussion in 'Archived Threads 2001-2004' started by DannyL, Mar 21, 2002.
  1. DannyL
    DannyL Stunt Coordinator
    Dec 18, 2001
    77
    i wasn't sure if i should put this in this forum or computers. does anyone use either the echostar or dishnetwork satellite internet connections. i don't have access to dsl or cable modem. how fast are the connections and are they worth the money for equipment and installation? also do you need a separate dish if you want hdtv capability?
  2. tony randall
    tony randall Stunt Coordinator
    Feb 16, 2002
    56
    I was just going to bite the bullet and sign up for earthlink's satellite when cable modems became available in my area. I don't know anyone who uses that service, but it is a 2-way, where AOL's is satellite down, phone up.
    Check out www.dslreports.com for information on speeds. It is an extensive site, and two weeks ago I was testing my down/up speeds there and did see references to satellite speed.
  3. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,307
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    When my provider of long-reach DSL went under, I bit the bullet and got the Dish Network offering (Starband).
    It's better than a modem - always on. The problem is that surfing is "bursty". You wait, wait, then suddenly most/all of your page appears.
    The request your browser makes goes to the central site, it collects the web page, compresses it and squirts it to you.
    Once you get used to it, it's fine.
    But cable modems and DSL tend to be better/faster/cheaper.
    The service is around $80 /mo and you must buy about $600 worth of equipment.
