Satellite Amplification
Discussion in 'Playback Devices' started by ThomasBorm, Sep 23, 2005.
  1. ThomasBorm
    ThomasBorm Auditioning
    Jul 14, 2005
    I am using a Direct Satellite system with a dual LNB running approximately 50 feet to a 4 output switcher. 2 of these outputs have to run an additional 300 feet. I have an in-line amp on each leg right after the switch but still have weak reception on the other end. Do I need to install another in-line in each leg about half way?
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,288
    51
    Mississippi
    Compare your signal strength (all transponders) at the end of the run to the signal strength at the dish. You will need a small TV, sat receiver an LONG extension cord but it is worth it. If there is very little difference, then your dish needs to be aimed better. I had 150 foot runs with no additional amps and I only lost 1 point of strength between the dish and the end of the run.
    -Robert
