Phil Iturralde
- Oct 7, 1998
No, but with JBL robust power handling rating (see below), you won't have to worry about overload. You audible sensory will overload before you blow the JBL speaker. You have more than enough 'head room' to play it @ Cinematic SPL levels if your neighbor's don't mind - w/sub of course.Movie DVD's: said:Quote:
JBL N24 SPEC: Maximum Recommended Amplifier Power: 100 Watts**
**The maximum recommended amplifier power rating will ensure proper system headroom to allow for occasional peaks. We do not recommend sustained operation at these maximum power levels.
Mini-Monitor SPEC: Suitable Amplifier Power Range 15 - 100 watts / Maximum Input Power 80 watts***
***With typical program source, provided the amplifier clips no more than 10% of the time.
For Reference:
JBL S26 SPEC: Maximum Recommended Amplifier Power: 150 Watts*+*
*+*The maximum recommended amplifier power rating will ensure proper system headroom to allow for occasional peaks. We do not recommend sustained operation at these maximum power levels.
Phil
