satelite and vcr
Discussion in 'Archived Threads 2001-2004' started by jeff cr, Jan 16, 2003.
  1. jeff cr
    jeff cr Agent
    Mar 2, 2002
    48
    just got a sattelite dish system and hooked it into my home theater system. Everything works great but somebody told me you can't watch one channel on the dish while taping another dish channel with the vcr. is this true. I tried it a little but had no luck. maybe there is a different setup to do this. thanks for the help
  2. Alf S
    Alf S Cinematographer
    Apr 23, 2000
    2,684
    440
    Alfie
    I believe you are correct.
    Now if you had a dual tuner receiver you could do that of course...I have a dual on my Directv Ultimatetv but haven't taken the time or money to run a multiswitch to both tuners.
    For me I just record what I want on the bedroom dish setup and watch whatever else on the "main" system.
    Alfer
  3. RobertSing
    RobertSing Agent
    Dec 13, 2001
    38
    Alf is right - you need a dual tuner Tivo or some other PVR.
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Jeff, did you buy DirectTV or Dish Network?
    Dish Network has something called a "PVR" Personal Video Recorder. This thing records shows like a VCR, but:
    - The recording is bit-for-bit identical to the orignal broadcast.
    - You have the ability to pause/rewind live broadcasts
    Once you use one of these, you will never touch your VCR again.
    The PVR-501 is a single-tuner unit (you can play something back while recording another channel) and the PVR-751 (?) is a dual-tuner (record 2 shows at once, watch one while recording another).
    Either one will change the way you watch TV.
    If you have DirectTV, they have a single-tuner PVR called "Direct Tivo". I dont know if they have a dual-tuner unit yet.
    Note: Some of the services are offering 2 receivers free. You can dedicate one to your VCR and the other one to the TV. This would also solve your problem, but be a little complex to use.
    Call your service and see if you can upgrade.
  5. Ken Seeber
    Ken Seeber Supporting Actor
    Nov 5, 1999
    787
    2
    ACtually, Bob, it's the PVR-721 that has the dual tuner. It also has a 120 gig hard drive and will record up to 90 hours.
    You can watch one show while recording another, record two shows at the same time, and record two shows while watching a third that was previously recorded.
  6. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,288
    51
    Mississippi
