With a smaller sat/sub speaker system, is it better to run the speakers to the sub and not use the sub-out on a Denon reciever? I read this and was wondering which way is best? Thanks
It would depend on what the manufacturer of your speakers recommend and what sounds best to you. In the past I owned an Energy Encore sat/sub combo and Energy recommended not using the sub out of your receiver. They suggested I use the high level speaker connections and use the crossover of the sub. In this case I agreed and so did my ears. I was able to blend the sub with the satellites better by using the subs crossover.
