jeff cr
- Mar 2, 2002
have a question about sattelite dishes. i have had direct tv with an rca reciever. When you go into the setup menu and go to dish pointing to check the signal strength, you can change the transponder number. i was just wondering what this is for. i can go from 1 all the way to 32. each transponder has a little different signal strength. does anyone know why you change these. i was just wondering because i am having problems with signal strength( due to trees being in the way.) all transponders give a signal strength of between 40-60 except for # 28 which gives a strength of 84. any thoughts. thanks
