JeffreyMercado
- Feb 1, 2002
This is a barely used Z2 front projector by Sanyo. It has zero dead pixels and has about 10 hours. I moved recently and my setup is not ideal. Plus being broke does not help much either. I am asking $1750 Here are the specs:
SANYO INTRODUCES NEW HD-PROPORTIONAL LCD PROJECTOR. With a wide 16:9 (1280 x 720) aspect ratio, the PLV-Z2 is great for viewing DVD or High Definition source material. The HD-proportional panels make it an ideal match for viewing 16:9 wide-screen DVD movies (480i, 480p) and HDTV (720p, 1080i) format programs. For High Definition sources, the panels provide better scaling and improved image quality than typical wide VGA resolution panels.
The PLV-Z2, with 800 ANSI Lumens, has a remarkable 1300:1 contrast ratio for picture optimization. Lens shift and a short zoom lens make it adaptable and versatile for home use. SANYO employs a whisper-quiet fan technology so you can clearly hear everybody eating their popcorn and the movie audio.
Product Specifications
Native Resolution: Native Widescreen HDTV (1280 x 720)
Lumens: (brightness) 800
Weight: (lbs.) 9.0
Dimensions: (inches) 14.1(W) x 10.8(D) x 3.8(H)
Zoom & Focus: Manual
Contrast Ratio: 1300:1
Aspect Ratios: 16:9 Native and 4:3
Lamp Life: 1500 Hours
Digital Keystone Correction: YES
HDTV Compatible: YES (480i, 480p, 720p, 1035i, 1080i)
Special Features: 4-Way Manual Lens Shift, Direct Component Video Inputs, DVI-I Input, S-Video and a Single Composite Video Input, HDTV Compatible, Backlit IR Wireless Remote Control, Only 24 dB in Theater Black Mode, Wide Angle Lens, 1300:1 Contrast Ratio
Warranty: Three Year Parts and Labor, Quick Repair Program. 90 Days Lamp.
Included Accessories: Composite Video Cable, Backlit Wireless Remote Control, and Owners Manual
Specs: Sanyo PLV-Z2 Spec Sheet
Weight: (lbs.) 9.0
