Santa Cruz output to amp or pre pro?
Discussion in 'Archived Threads 2001-2004' started by Chris Tsutsui, Mar 14, 2002.
  1. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    I'm thinking of using a Parasound HCA-1000a to power some JBL S38ii studio speakers. The parasound amp has a left/right rca inputs and I'll be hooking the amp to a Turtle Beach Santa Cruz.
    I assume I'll need a stereo mini audio plug to left/right RCA adapter in order to hook the amp to the front left/right output on my sound card.
    Later, I would like to hook a pre pro to the sound card instead of the amplifier by using the single digital encoded Digital Dolby® output on the sound card. That would mean I would need an adapter from digital coaxial (for pre pro) to digital mini plug (on sound card) so I can plug it into the versa jack on the Turtle Beach?
    Am I correct with this because right now I don't have ANY home theater equiptment or even a sound card.
    Anyone know if the radio shack adapters are any good or would I be better off soldering my own?
  2. Matt DeVillier
    Matt DeVillier Supporting Actor
    Sep 3, 1999
    773
    Chris,
    your assumptions are correct. You need a 1/8" stereo to RCA stereo cable for the analog out. For the digital out, I'm pretty sure all you need is a 1/8" stereo to RCA mono adapter plug, and a single RCA cable. You select AC3/DTS output in the TBSC control panel, and you are all set. Radio shach should have all the stuff you need.
