Samsung UHD Blu-Ray Player Help (1 Viewer)
Brian Martin_280866
Brian Martin
At the very start of a video and menu on a Blu-Ray on my Samsung UBD-M9500, there is almost always a second-long delay for when the audio comes in. Could someone please help me fix it, if possible?
I have a completely different player (Philips), and that happens on mine as well. I think it's just a handshake issue with the HDMI chain in our set-ups. I'm not sure there is anything that can be done.
If you have a high speed premium cable that can do speeds of 18Gbps, switching it out with another one won't likely do much good. If you're using an old, uncertified cable, a new high speed one wouldn't hurt.
Brian Martin_280866
Brian Martin
I use an Audioquest Pearl HDMI cable. It says "High speed with ethernet" on it.
Mark-P
Camas, WA
Mark Probst
I have Sony players which do the exact same thing. It seems to be a normal occurance for high resolution audio, which takes a second to decode. I simply start the movie, then skip back to the beginning to get uninterrupted audio. Annoying but manageable.
dpippel
Yoyodyne Propulsion Systems
Sonora Norte
Doug
Do I need a new HDMI cord?
In short, yes. If your HDMI cable is not "Premium Certified" with this logo, then it's a crapshoot as to whether or not it will work reliably with 4K UHD. Monoprice sells these cables at a very affordable price and they work great:
