Samsung TXN3245FP - is 32" big enough?
Discussion in 'Displays' started by Mando-R, Oct 19, 2003.
  1. Mando-R
    Mando-R Stunt Coordinator
    Jul 29, 2003
    62
    I want a television that has progressive scan capability so I can watch movies with progressive scan, and I want it to be big enough that I will truly be suprised by the image quality. Our room is close to a 12' x 10' with the TV planned to be on the 12' side. Would a 32" be enough "TV" for this size room? If not, then I have no choice but to go with rear projection and for it to take a long time, because the cheapest HDTV RPTV I can get will cost me $1130.
  2. John Robert
    John Robert Stunt Coordinator
    Sep 6, 2003
    193
    You don't say how far you will sit from the set but 32" will not give you much of a HT experience unless you are 6' or closer. Do a search for "seating distance"...
  3. Mando-R
    Jul 29, 2003
    62
    Heh, well if it's any condolance, we'll be sitting 5 feet or less away. I did say how big the room is, and chances are in a small room of such size, we will be sitting 6' away at a minimum.
