Samsung TXM2796HF
Discussion in 'Archived Threads 2001-2004' started by John Bryant, Sep 27, 2002.
  1. John Bryant
    John Bryant Second Unit
    Mar 18, 2002
    381
    110
    I would love to get this tv, but I have some questions. First, how exactly do I take advantage of the HDTV-capabilities?
    Second, if I don't have an HDTV signal, can I still take advantage of progressive scan, 480p and such on my games and dvd's?
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    You need an ASTC decoder (or HD set top box). Several options:
    If all of your HD source is from local, over the air channels, you can by a STB that only decodes OTA signals. Samsung makes a well-known OTA STB. You don’t necessarily need a special antenna, if you already are getting good, local reception, chances are that you will also get good local, digital reception.
    There are cable STB that decode both SD and HD from cable and also decode OTA signals. This is useful if your cable system carries HD channels. Not many do.
    There are satellite STB that decode both SD and HD and OTA signals. This is a good option if you have Dish or DirectTV service.
    If you don’t have Dish or DirectTV, there are deals available that will give you free installation, providing that you sign up for one years programming.
    If you are already a customer of DirectTV (I don’t know about Dish, but they are probably competitive), you can get a break on their elliptical dish (required for the HD channels) and get free installation, if you sign up for another year’s service.
    DVDs look great on this set. I can’t comment on games.
  3. John Bryant
    Mar 18, 2002
    381
    110
    Thanks. But do I need one of these boxes to just get progressive scan and other things to work?
  4. Evan Hartnett
    Evan Hartnett Stunt Coordinator
    Jan 9, 2002
    118
    No, the set top boxes are just for HD signals (1080i, 720p). FOr progressive scan games and DVDs you don't need the set top box (although for the Xbox you would need to get the high defintion kit, it's around $20).
  5. John Bryant
    Mar 18, 2002
    381
    110
    Cool, I already have that(the hi-def kit). So, a progressive scan dvd player and games would work as long as they are hooked up with their respective compnent cables, correct?
  6. Evan Hartnett
    Jan 9, 2002
    118
    Yep, just plug in the component cables and you're all set.
  7. John Bryant
    Mar 18, 2002
    381
    110
  8. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    In all practicality yes, you need an HDTV-ready set to take advantage of a device that outputs 480p. Samsung did make a line of sets that they called EDTV-ready a few years ago. It essentially handled a 480p signal in addition to the usual 480i NTSC signal. I'm actually surprised more manufacturers didn't come out with a 4:3 480p capable set that also did a 16:9 squeeze/compression since I think there would have been some demand for these. But I can see why they didn't - with HDTV soon coming down the pipeline, they've devoted resources to making full blown HDTV-ready sets.
    cheers,
    --tom
