samsung TXL3696, any feedback? (1 Viewer)
Robert Mayrand
I can get this set for about 650$ (well actually 999$ canadian). anybody can comment on this set. This is about the most money I can spend. My first instinct was to go with a sony27fs17 for the flatscreen and mainly the vertical compression. But then i was quite tempted by a bigger screen altough not flat Toshiba 32a41 but the lack of vertical compression trough user menu is a bit of a turn off......but then i stumble on this samsung with the compression and regular screen with a BIG screen..........it's quite tempting!!!!! Any problem or thing I should no about this set.
Thanks for you comment.
Mtl
Bill Will
Try doing a search on it because someone just got the 36 inch Samsung & was very happy with it. If I was in the market for a set I would buy either the 32 inch or 36 inch Samsung until the price of HDTV sets come down in price. For features, price & picture quality I don't think you can beat Samsung, but I've been a big Samsung fan. I only wish that they would put their 32 inch Flat Tube in an analog set at reasonable price.
Bill Will
Oh, make sure that model has Component Video Inputs if not go for the model that has them because the newer model has the Component Inputs & the older one doesn't & they both sell for around the same price.
Robert Mayrand
This is actually the TXL3676 not 3696 sorry a little typo.
But actually it is the one with component connection!
Rob
Mindy
