RudyN
http://www.samsungusa.com/cgi-bin/na...elTab=Features
We just recently starting selling this tv where I work(Target). Anyone have this tv or know anything about it? These are the specs from the website:
Features
TV/VIDEO:
Built-in HD/Digital Tuner (ATSC/QAM/NTSC) ? Tunes & processes 720p, 1080i, 480p, and 480i signals
Premiere Series Sleek Simple Design With Front Panel Control Buttons
16:9 Wide Screen Aspect Ratio
Native Resolution 1080i/480p
Dual HD Supports 720p and 1080i HD Signals
DynaFlat? HD Anti-Distortion, Anti-Glare Flat Picture Tube
Finer Pixel Dot Pitch Flat CRT Improves Picture Resolution and Brightness
Pro Picture 3-Stage Video Correction
- Total DSP (Digital Signal Processing) Analog to Digital Signal Enhanced
- Pro Chip Plus Converts all Analog Signals to Flicker-Free Progressive Scan
- 8 Bit 20 MHz 3D Y/C Comb Filter
Velocity Scan Modulation Improves Edge Detail
3:2 Pull Down Film to Video Frame Rate Correction
Check HDTV Reception with a Built-in Digital Signal Strength Meter
Convenient Front Panel Control Key Buttons for Accessing Menu Settings Without the Remote
Universal Remote Control
Easy Navigation with Translucent On-Screen Display
Screen Filling Modes & Vertical Compression for Anamorphic DVDs
Digital Program Guide (where available) AUDIO FEATURES
20-Watt Side Speaker Audio System with Sound Presets
Is it worth the $700 price tag? What else would I need to view HD signals? It would also be used to play Xbox(720p) games. Pros/cons? Thanks in advance for any responses.
Features
TV/VIDEO:
