Mike_P
- Dec 1, 1999
I just got this unit hooked up in my system a few days ago, and I have noticed a few things. I was wondering if anyone else had similar experiences.
First, the 351 will not display 1080i in letterbox on a 4:3 tv. Naturally, I have an older 50" Toshiba. Many newer tv's have a 16:9 mode, which would solve the problem, but that feature came out a year or 2 after my set was made. The 351 will display 1080i in 2 modes, zoom and full. Both distort the aspect ratio.
Samsung's work-around is to set the 351 to 480p. This will display 16:9 material in a letterbox on a 4:3 display. It seems like a waste to display an HD picture in 480p, but the picture is still jaw-dropping.
I also have problems with the digital sound out of the 351. I kept getting dropouts on all the stations I get, even the ones with very strong signals(10 bars). My receiver is a Yamaha RX-V995. I have tried an optical connection to the Tape In and a coaxial connection to the CD in with the same results.
I have discovered that if I set the digital sound output to PCM instead of Dolby Digital, the dropouts magically disappear. I suspect, but can not prove, that the Yamaha, in Auto input mode, is losing the signal and re-detecting whether it's DD, DPL, or DTS.
I have also connected analog audio out of the 351 to the VCR 2 inputs on the Yamaha, and the audio never drops out. I suppose the digital sound dropouts could be caused by the broadcaster, but it happens on all stations I can get.
One more interesting thing about the tv and the 351. The Toshibas ColorStream (component) inputs can be set to DVD or DTV, which I think means 480i/480p set to DVD, and 1080i set when set to DTV. When I switch the 351 from 480p to 1080i, or vice versa, the picture disappears for about 5 seconds and then reappears, regardless of the setting on the ColorStream input! I thought this was odd!
Anyway, I have rambled on for long enough. I would appreciate hearing from anyone else with 351 experiences.
Mike P
Mike P
