Samsung service menu ?
Discussion in 'Archived Threads 2001-2004' started by Charles L., Feb 18, 2002.
  1. Charles L.
    Charles L. Agent
    Dec 21, 2001
    34
    Does anyone have the service codes for a hi-def samsung?
  2. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,307
  3. Dave Bennett
    Dave Bennett Screenwriter
    Aug 11, 2000
    1,167
    Charles, Joel Ostrow has a copy of the service manual for the TXL2791F and it's apparently not very clear on some of the values in the service menu. The one thing it did say is that the menu labeled G2 Adjust should not be entered or changed FOR ANY REASON as it could fry your set. Try contacting Joel but also tread with caution if you try fiddling around. Be sure to write down each and every default value before attempting to tweak. Good luck
