Samsung RPTV Focusing question
Marko58
Mark
I have a samsung rear proj TV, There is an auto focus button on the remote and when I activate it, it goes through green, red and blue focusing steps. The blue is very blurry, although the picture is not really bad. The blue gun rotates after you loosen a wing nut. Is this the way you focus it? I tried the convergence controls and can't really notice a difference.
Gregg Loewen
Founder, Professional Video Alliance
Insider
New England
Gregg Loewen
yes....there is also a 6 pack of knobs under the hood. 3 are for electrostatic focus, 3 are for voltage agjustment. make sure you are adjusting the correct 3.
Regards
Gregg
Marko58
Mark
Do you think it might be the timing cap? Does the samsung use a capacitor or servo-lock?
Druiz23
