Brian:K
- Mar 7, 2004
Just when I thought I was finally getting a grasp on all this...
I've done some research on dvd players and I finally decided to buy the Samsung HD931. Although I don't have a DLP, I do have a 65" Mitsubishi RPTV (65413) with a DVI input, and I'd like to get the best picture possible out of it.
I bought the HD931, hooked it up, and started to read the manual and play around with the features. I read that the faroudja deinterlacer only works with the DVI output, but the DVI output is disabled if progressive scanning is enabled. In fact turning on the progressive scan disables all the outputs except for component. I was under the impression that the Samsung was a progressive scan dvd player with the faroudja deinterlacer and a DVI output. It doesn't make sense that all these features don't work together.
I know I'm missing some basic concept here. You guys would be *all over* this Samsung dvd player if this was a bad thing. So someone please straighten out this confused home theater novice!
Brian
Brian
