Lew Crippen
- May 19, 2002
Make sure your display is HDCP compliant or the HD931 will not work in anything but 480p.Thanks for the heads up Mike.
There is really only two sub $1K DVI players:
Samsung HD931
Bravo D1
Each have their pluses and minuses.
Don't forget the Momitsu V-880. It has a DVI-I connector instead of just DVD-D. So, you can use it with a DVD to VGA converter for those of you without DVI inputs on your display that still want the scaling. It's about $200 or so too.
http://www.keohi.com/keohihdtv/video...ackground.html
