Dave>h
- May 1, 2004
Hi all,
I have a Samsumg DLP 61". It is about a year old now.
I notice, on close up inspection, that one "pixel" does not seem to work correctly. I don't notice it from my seating position - about 2.5 screen lengths - so it isn't that big of a deal but I am curious if it is the start of a larger problem.
I guess the questions I have are:
1) Is this something I can fix? Is there a reset button or can I check the chip for dust or dirt particals or something like that?
2) If one mirror goes, can I expect more to go?
3) Any one out there have a similar problem? What did you do to rememdy the problem?
Thanks very much for any and all comments
Dave
Dave
