Samsung DLP Owners...
Discussion in 'Displays' started by John Robert, Sep 12, 2003.
  1. John Robert
    John Robert Stunt Coordinator
    Sep 6, 2003
    193
    I am awaiting delivery tomorrow of 46" set and wondering what quick out-of-the box calibrations you did on your new set. Also does set come with a DVI cable? If not, which one did you purchase?
    Thanks for your help...
  2. Brian OK
    Brian OK Supporting Actor
    Aug 29, 2000
    550
    John,
    Best to head over to www.avsforum.com and seek the RPTV forum. Just volumes of info about Sammy DLP's, and then some.
    NO DVI will come with the Sammy DLP 46" set you bought. You are on your own.
    You will also find cable recommendations there as well.
    www. pacificcable is an inexpensive one and many use it with success. You will need the "DVI-D" listed model if you are looking to buy a DVI cable.
    Good Luck,
    BOK
  3. WojtekZ
    WojtekZ Extra
    Jul 30, 2003
    19
    Where did you pick up the 46" ? How much was it ?
  4. John Robert
    Sep 6, 2003
    193
    I bought it from Ultimate Electronics here in Las Vegas. Price was $3119 + tax after much back and forth negotiating...
