DonovanCampbell
I just picked up the new Samsung BD-P1200, and after hooking it up to my BenQ 8700+ using both HDMI and Component, I've found that component works just fine up to 1080i, but HDMI gives me '525p' output to the 8700 that is nothing but a wavy, distorted picture, and provides no way to change any display setting in HDMI.
I am using an HDMI-DVI adapter that works correctly with my Toshiba HD-A1, running through a Gefen 2 input DVI switch.
I've tried running the HDMI directly to the PJ with no difference in the distorted picture. I also tried the player on my upstairs HD CRT TV with an HDMI input, and it synced up properly with a perfect picture at 1080i and 720p.
Once I was able to set the player to HDMI 720p output, using my CRT, I reconnected the player to my 8700+, and it had a proper 720p picture for about a second before resetting itself back to '525p' and the crappy distorted picture.
From my 'playing around', I've determined that it's not the player, the HDMI cable, the HDMI/DVI adapter, the Gefen DVI switch, or the projector. The only thing I can think of is that in the HDMI handshaking, the Samsung is ignoring it's own resolution setting, and automatically trying to resync with the 'best' resolution of the BenQ, which it doesn't handle well at all.
Any ideas/thoughts/suggestions?? I hate to try and take this back, as I've trashed the box it came in, but to me, it is defective, as it doesn't properly deal with HDMI/DVI which the manual states it does, and I want the HDMI for DVD upconversion.
AV chain: Samsung BD-P1200 HDMI --> HDMI/DVI adapter --> Gefen 2 port DVI switch --> BenQ 8700+ DLP projector (native 720p)
