rgtsc01
- Oct 28, 2008
- Robert
Just got a 46" Samsung 850 and cable box is MOT DCH3200.
According to the Samsung manual, you can control the cable box (STB) with the Samsung controller if you program it using the Motorola code. This would allow control with just one controller of both the TV and cable box.
I performed the programming procedure over and over using the code they suggested for Motorola, but it has not worked.
Does anyone have any suggestion? The code is a three-digit code.
